When researching ways to go about modifying an IKEA Vindriktning I found these links quite helpful:
- Sören Beye's original mod on GitHub
- @lond's #IKEA Vindriktning PCB
- Michi Lehr's build including a CCS811 sensor
- Blakadder's build with all the sensors, especially the tip to use the tasmota-allsensors build in order to not have to build a custom Tasmota version
- Usage of WS2812s with Tasmota
- List of Tasmota compatible sensors
Just now I came across @Catalin Sanda's #IKEA Vindriktning Daughterboard... if only I had found this sooner...
On the software side I used
- Tasmotizer to flash tasmota-allsensors (see above)
- and followed Jon Oxer's instructions on setting up MQTT, NodeRed, InfluxDB and Grafana
I read somewhere that Apparently the Vindriktnings color thresholds are a bit optimistic so I tried to find more reliable ones for PM2.5, VOC and CO2 but I'm not very happy with the results:
- PM2.5: https://blissair.com/what-is-pm-2-5.htm
- PM2.5: https://en.wikipedia.org/wiki/Air_quality_index#CAQI
- VOC, CO2: https://cdn.hornbach.de/data/shop/D04/001/780/491/871/060/10176848_Doc_03_DE_20201103134757.pdf
- CO2: https://www.breeze-technologies.de/blog/calculating-an-actionable-indoor-air-quality-index/
If you have a good source, please leave a comment.
Edit 2022-06-22: Added link about Vindriktning color thresholds.
