close-circle
WW50: Wire-wrapping is too boring
A project log for Brainfuck relay computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
Artem KashkanovArtem Kashkanov 12/14/2017 at 07:230 Comments
I start wire-wrapping on Adder block. Hundreds wires per block.
Just at the beginning of the process - only GND line is connected yet(already not). Thats my first steps in wire wrapping
Do not buy Blue wire if you want to use it with blue pcb! :(
Current number of modules soldered - 64 - so it's 1/3 of overall modules count.
