WW12 Worlds-Fastest Relay Adder Test - 500OPS
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
Artem KashkanovArtem Kashkanov 03/22/2018 at 07:215 Comments
Insane five hundred ADDC operations per second to the relay!
0x9999+0x6666 + Carry = 0x10000 with Carry and 0xFFFF w/o it, so All digits are involved
World-Fastest relay adder exist  - Time to go to the worlds-fastest relay computer
Ted Yapo wrote 03/22/2018 at 12:26 point
First program should play a tune on those relays :-)
Artem Kashkanov wrote 03/22/2018 at 19:41 point
There would be external XTAL input for midi keyboard:)
Yann Guidon / YGDES wrote 03/22/2018 at 11:26 point
You can run the frequency generator to 500, but you also have to make sure that the whole circuit still works :-P
Whole circuit will work on 100Hz only, and after all experiments I'm sure I can do that :)
Yann Guidon / YGDES wrote 03/22/2018 at 19:56 point
I can't wait to watch it run some Linpack/Whetstone/Drystone benchmarks :-P
