CMD/TMP register wire-wrapping process
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 08/24/2018 at 19:570 Comments
Vacations gone so I have to return to work on the project :)
Current task - to wire-wrap CMD/TMP register block. It's 80% done. Just need to add VCC and WR lines (but want to go to sleep...)
This block contain 3 registers:
16-bit TMP register for Adder A-input
12-bit BIAS register for Adder B-input (4 MSB bit are extended with sign)
4-bit CMD register for Sequencer input.
We load data from Memory to TMP register and load 16-bit width code instructions to BIAS+CMD register.
