WW52.1 16 bit ADDer Wire-wrapping DONE!
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 12/25/2017 at 09:034 Comments
I'm done with Adder block wire-wrapping. 32 modules, 2 modules per bit. Bit Placement:
Top rows - FEDCBA98, Bottom rows - 76543210, So two bytes in natural view
Not good with wire-wrapping yet - can't place wires smoothly, but already can do isolated turns.
Next steps -  need some test suite for checking blocks
EricH wrote 12/25/2017 at 20:56 point
impressive! Tip: assuming you're using one of the screwdriver-type tools, only press the tool down for the first few turns (insulation), then let the weight of the tool handle the rest.
Artem Kashkanov wrote 12/25/2017 at 21:06 point
Yes, I'm using screwdriver-type tool, but do some non-stable pressure during the whole process.
Thank for advice - I'll try your tip while doing register blocks.
Dr. Cockroach wrote 12/25/2017 at 12:14 point
Your wire-wrapping looks a lot better than what I was doing in the 70's :-) I am excited to see how well your Brainfuck computer works :-)
Artem Kashkanov wrote 12/25/2017 at 21:04 point
Thanks! I hope I'll done with first revision in 2018 :)
