Product Specifications
General
Type: LED (Light Emitting Diode) Bluetooth Control Module
Architecture: For all electronics devices (with iOS and Android capability)
Bluetooth Version: Bluetooth V4.0 BLE (Bluetooth Low Energy)
Radio Frequency: 2.4 GHz
Display Colours/Patterns: Any colours of the spectrum + customisable patterns
Operating Temperature: -30°C-80°C
Supporting Data Transmission Rates: 250 kbps & 500 kbps
Supporting Devices: iOS and Android Devices
Supporting Application Name: LED BLE (on App Store or Play Store)
PWM (Pulse Width Modulation) Operating Frequency: 20 KHz
Power
Power Input Connection: Micro-USB
Operating Voltage: +3.6 - +5 volts
Operating Current: 15mA
Sleep Mode Current: 2µA
Weight and Size Dimensions
Product Weight: 8g
Weight and Size Dimensions: 49.7 x 49.6 mm
Product Review
After reviewing this unique Bluetooth module from ICStation, I spotted a few significant factors which added to the value to this product which include:
1. The portability and size of this product, which you can control from the smallest of locations, which you could mount this module to.
2. The immense software which you can change, alter and customise every aspect of the control you have over this module, which includes the colour, the pattern, the music which it moves to, the brightness etc
3. Its ability to connect to the most common operating softwares (iOS and Android) with ease and no additional preparation required in advanced (with the exception of downloading the app).
4. The minimal amount of power consumption which this product takes up, which is very low, considering the capabilities of powering the LEDs and Bluetooth module on-board.
ICStation Product Page
Check out the product here: http://www.icstation.com/product_info.php?aid=294&products_id=12050
For purchases from ICStation, use this code for a discount:
Code: Simics
Discount Amount: 15% off
Max. Use: 1 (one per user)
Amount Limit: 300
Be sure to check out the LED Light Control Bluetooth Module for iOS/Android Setup by clicking here.
Amazing Opportunities
Also, be sure to check out PCBWay, a leading manufacturer and distributor in PCB design and manufacturing. They have amazing prices and excellent quality in their services, so don't miss out on them! Plus, PCBWay has an amazing website, online Gerber viewer function and a gift shop so make sure to check out their links below:
PCBWay Free Online Gerber Viewer Function: https://www.pcbway.com/project/OnlineGerberViewer.html
PCBWay Gift Shop: https://www.pcbway.com/project/gifts.html
Enjoy! Contact us for any inquiries!
Emilio P.G. Ficara
Hexabitz
