HP54542_ctl_04_14_2025.tgz
This is the new parser code mentioned in the logfiles. A significant number of commands have been added compared to the original code. Still no README file, but this builds with the instructions in the text above. <br>Fixed some un-initialized variables in parse_and_exec.c that were preventing the low level device functions from being called. Strangely, the previous code worked fine on an older version of the C compiler and did not generate warning messages with the newer version. This should still be considered Alpha code until I get a lot more miles on it.
x-compressed-tar -
38.48 kB -
04/15/2025 at 01:13
