Getting the OLED working
A project log for 1 kB Arduino Roguelike
1 kB roguelike using an Arduino and 0.96" OLED
radekRadek 12/03/2016 at 17:000 Comments
I bought one of these OLED from ebay for ~$5. I used this page as a guide for the wiring and code:
https://github.com/jandelgado/arduino/wiki/SSD1306-based-OLED-connected-to-Arduino
The Arduino communicates using the SPI
I have the wiring as follows
OLED - Arduino pin - AVR pin (PORTB) - Function
D0 - Pin 13 - B5 - MISO
D1 - Pin 11 - B3 - CLOCK
RST - Pin 8 - B0 - RESET
DC - Pin 9 - B1 - Data/Command
CS - Pin 10 - B2 - Chip select
First I set-up the AVR peripherals (using http://brittonkerin.com/cduino/lessons.html as a guide for uart). UART is used for debugging:
setup_uart:
    ldi        r16, low(bittimer)
    sts        UBRR0L, r16
    ldi        r16, high(bittimer)
    sts        UBRR0H, r16
    ldi        r16, (3<<UCSZ00)
    sts        UCSR0C, r16
    ldi        r16, (1<<RXEN0)|(1<<TXEN0)
    sts        UCSR0B, r16
    ret
To send a byte over uart I store it in r16 and invoke the tx_uart subroutine
tx_uart:
	lds	r17, UCSR0A
	sbrs	r17, UDRE0
	rjmp	tx_uart
	sts	UDR0, r16
	ret
Setting up the SPI:
setup_spi:
	ldi		r16, (1<<5)|(1<<3)|(1<<rst)|(1<<cs)|(1<<dc)
	out		DDRB, r16
	ldi		r16, (1<<SPE)|(1<<MSTR)
	out		SPCR,r16
	ldi		r16, (1<<SPI2X)
	out		SPSR, r16
	ret
To send a byte over spi I store it in r20 and invoke spi_send subroutine
spi_send:
	out	spdr, r20
wait_sprs:
	in	r16, SPSR
	sbrs	r16, SPIF
	rjmp	wait_sprs
	ret
