PulseGen Modifications
A project log for 10 MHz GPS Frequency Standard
Stand-alone GPS based design does not require PC. Generates a 10 MHz output after satellite lock.
land-boardscomland-boards.com 07/03/2022 at 18:100 Comments
Some minor mods are required to the PulseGen card as a 50  Ohm driver These involves removal of the Oscillator R/C parts. If you order a PulseGen card from us on Tindie please let us know in the notes with your order and we will pre-build it with these mods.
Schematic Modifications
PCB Modifications
The PPS out of the GPS gets attached to the pad as shown below. I used Superglue to hold the wire to the pad.
