FSAE 2014 Electric Race Car
F-1 Electric Race Car
This was last years project. The 2015 car is located here: https://hackaday.io/project/6497-fsae-2015-electric-race-car
Here is the electronics for The University of Akron 2014 FSAE ev car. To get a better understanding of the project I am attaching a system diagram here.
We decided to do what we like to call "distributive computing." This allows us to break up the tasks to different processors to allow the system to be more flexible and run faster. I costs more of course but if there was an error with one system, only that board needed to be replaced and not the whole thing. It also allows for smaller boards instead of one larger board. This makes it easier for our ME friends to hide the boards close to where the tasks inputs / outputs are for better integration and good noise immunity.
BMS-
This year we designed our own BMS with a very high bypass capabilities for faster charging. (1A)
They talked to the master threw an RS485 bus in a 8 pin IDC cable.  This is more than adequate for charging and discharging. We control the bypass in software or hardware. We finally chose software so we could turn them on when ever we wanted. This allowed for a more controlled charge of the pack. We had the ability to set hardware addressing on each PCB. They have also the ability to do a "pack" interrupt in case there was an emergency on the cell it was monitoring...
ECU, Safety, BMS master -
This box contains the main brain of the car, the ECU. That is the board on the top left. This gathers data about the car and decides what movements will go down to the two independent rear wheel drive motors.
ECU -
BMS-Master
This box also hold the BMS master and safety systems. The safety system does what the name states, it makes the car safe to drive by wire.  And we want to be safe driving the car. This monitors all the safety switches and safety systems on the car.  It has the ability to tell the ECU what faulted the car (shut it off) to our wireless serial terminal. The safety board also controls pre charge, main, and discharge relays.
Safety-
The BMS master talks to all the slaves and monitors different statics and conditions. We can talk to the entire pack in less than two seconds. It also acts as a charge controler.
Motor Controller ^2
This is two kelly motor controllers that control the two independent motors driving the left and right side of the car. You can also see the gray box that holds another custom board that converts the RS485 serial stream coming from the ECU to an isolated analog output. The board also monitors motor temp and motor controller LED status codes.
The SAS -
This board takes all the analog inputs (two for break, two for gas, and steering wheel position) and 4 speed sensors to make a clean software filtered digital serial signal to the ECU. It also controls the brake light.
  • Charger
    Richard Johnson08/20/2014 at 01:58 0 comments
    Today we worked on the charger. We wanted it more user friendly. Having it more "automated" allowed me the safety officer and head electrical engineer for the project not have to be there to charge the pack up. We were lucky to find a power supply at our school that would allow analog signals to control the charger. We have been trying to get the DAC's on the control board to work. Getting I2C to work on the dsPIC is not fun. We are also interfacing with a 4D 4" display to show battery info. More work needs done on the algrorithem but it is close.
  • How to update boards
    Richard Johnson08/19/2014 at 03:47 0 comments
    One thing we are working on is a RS485 bootloader for the car. This will detect multiple devices and upload sequentially to one or all boards at once. This will allow for better software updates without having to take the car apart! Wish us luck!
  • Safety Board relay issue
    Richard Johnson08/19/2014 at 03:44 0 comments
    So one issue we had at comp is a little relay chatter. I thought it was battery issues and let it go for the time. We got back and it was really annoying me. So I pulled the safety board out of the car and ran some tests on it. Come to find out the issue rose its' head w/o relays attached. It had to do with our ~5 second precharge timer. We had a R/C timer go into a opamp with a pot to set the device as a comparator.  I am guessing the op amp didn't have enough open loop gain to go from low to high cleanly. So we got this high ringing on the output. We fixed this with a pull up and pull down resistor in the precharge system.
  • Repair
    Richard Johnson08/19/2014 at 03:22 0 comments
    So we have been working on motor repair lately and some software upgrades. We were checking the timing of our two motors and found that one brush got damaged. We are still waiting for a replacement. While we are waiting on the brush, Our software guy was busy on updates to the car and adding features. More to post soon.
View all 4 project logs
doubleman2014 wrote 09/18/2014 at 13:49 point
in the fact,I mean the MCS,you use the driver model or you design it.
Richard Johnson wrote 09/25/2014 at 02:57 point
The MCS is something I designed. But it isn't what controls the motors directly. We have an in between the MCS and the motors. It is a kelly controller The KDZ model.
doubleman2014 wrote 09/16/2014 at 07:00 point
This is a great project
I'd love to know the EV controller,because I think it is the most important in this system.
and I'm interested in it。I want to know the power of the EV controller.
Richard Johnson wrote 09/17/2014 at 14:22 point
Are you asking about the ECU?
Richard Johnson wrote 07/11/2014 at 18:12 point
This is just a small section of the car. We are taking pictures and uploading our schematics and bill of materials. To answer your question, Yes, it uses a bypass resistor. We track battery capacity (current) overall and looks at voltage (at each cell) to bypass. This tells us individual battery level. We use our own communication protocol over RS485 to each board. As with other systems on the car use RS485. Also, the car uses xbee modems to configure the car and get diagnostic data.
Mike Szczys wrote 07/11/2014 at 17:46 point
This looks great! Can you share more details?
I'd love to hear more about how each battery is monitored. Are they shunted out of the array as they reach full capacity? Do you do capacity tracking over the live of the array? You also need to document how data is being transferred between each board the main controller.
