- Eight RGB LEDs around the edge and one under-key LED, with fully programmable 16 million colour backlighting.
- Piezo speaker
- Only 34×34mm PCB. Clearances are sized to be suitable for most 4-layer board services.
- Mostly single-sided SMD components so can be built in singles, with minimum special equipment.
- Nothing smaller than 0402, designed to be built by hand with care.
- Small enough to build on a mini-hotplate.
- SAMD21 microcontroller with flash, so fully Arduino and CircuitPython compatible.
- One under-key RGB LED and eight ordinal RGB LEDs around the under-board edge.
- USB-C for power and data.
- Kailh hotswap sockets and centre hole to use with any Cherry MX compatible switches.
- 3D printable enclosure
- M2.5 bolt closure for easy access and hacking.
- Optional LED and I2C outputs to connect to other devices.
- Able to emulate keyboard, mouse, game controller and have serial communication for bi-directional communication.
DefProc Engineering
Kutluhan Aktar
ilo
Tina Belmont
Ray Burne
