Ampere and Voltmeters for the Constant Current LED Tester
A project log for Muffsy Constant Current LED Tester
Open Source, Versatile LED Tester with Eagle Project Files
skrodahlskrodahl 10/11/2017 at 09:100 Comments
You can of course just use your multimeter for this, These are great if you want to build the project in an enclosure, making it completely stand-alone.
The "Ultra High Accuracy" ampere and voltmeters from eBay seller elite.element seem to be a great fit for this project:
http://stores.ebay.com/Elite-element/_i.html?_nkw=accuracy&submit=Search&_sid=897140872
Basically, I found the milliammeter very suitable and found a matching voltmeter.
I have no affiliation with the seller, but I have ordered these.
