Finally, I create something that I can actually use to get a feel for the project.
It looks like the cheap switches I used are garbage because they feel different. Some are clicky, others are mushy. There may be the problem with the caps or the case as well.
I plan to learn how to touch type on this keyboard. Perhaps I should put marks on the caps.
