PICO based single board panel.
https://www.hackster.io/news/bobricius-picotouch-hmi-is-a-raspberry-pi-pico-carrier-for-your-human-machine-interface-projects-794b5957d5d0
Where do you get those reset button switches that mount on the back of the PCB? What did you search for?
it is standard TH switch just I bled legs to UP ;)
What did you use for capacitive touch sensing? Don't see a MPR121 on the board... Really nice design with the pcb as the front panel!
touch is made in software
Very cool! Saw posts on some forums about doing that in assembly and also micropython. Is your source code available anywhere?
It is from circuitpython touchio example 2-3 lines of code
Display looks really nice. Can you share any info about where to get it?
It is clastic cheap aliexpres 0.96" IPS ST7735 display
Hosein Movahedian Attar
jareklupinski
Kolton B
Just4Fun
Yes, delete it Cancel
You are about to report the project "PicoTouch HMI", please tell us the reason.
