This project will involve some construction techniques for encasings I have not tried ever before, so it will take some turns, I’m sure. It will involve 3D-printing some parts.
This project will also involve as many sensors I can get working and can fit into a special case of casing.
The point is to document everything here for you to see, and hopefully clear enough for you replicate, if you want.
If you follow, you will find out what this will become :)
Some info to be found here: https://memory-alpha.fandom.com/wiki/Scanner
Leonard
Quite bulky indeed!, imagine that the Vulcans were doing scans in space for a long time already, way before humans joined the warp highways. Anyway it is as it is.
Kevin Osuna
txdo.msk
