Print is finished, and now that I have a test-ring of some sorts I can try some finishing and sanding etc.
I'm not convinced this is exactly the result I want. More on this later.
..the result
A project log for Vulcan Scanner
Dome-shaped sensor with a triangular handle distinguished by a silver-colored readout portion and a blue handle with black grips
..the result
