1Install Arduino IDE with ESP32 support
There are plenty of instructions out there: I cant explain it any better: https://randomnerdtutorials.com/installing-the-esp32-board-in-arduino-ide-windows-instructions/
2Download and install the needed libaries for Arduino IDE
3Solder or connect a CC1101 Board to an ESP32 Mikrocontroller Board
4Download the Reciever Files from Github
For basic Testing try this sketchand compile it
https://github.com/Uspizig/Bresser_Weather_NEW/tree/main/CC1101_Receive
5Upload the compiles code to your ESP32 Board.
6Have fun recieving weather data
Wait 3 minutes and check if data is received and printed to serial monitor in Arduino IDE
The result should look something like this
7Try out the more advanced steps to Transmit data via LoRA
Try to compile this code: https://github.com/Uspizig/Bresser_Weather_NEW/tree/main/LORA_CC1101_WIFI_LOCATIONV3
Change your credentials in the file lorapindef_and_features.h first.
You can get your Access data on TheThingsnetwork or Helium
How to get credentials is explanied pretty good here: I cant explain any better: Only use MANUAL as a Device Manufacturer
8Install a Payload Decoder to make Data more readable
get the Payload Formatter from here: Github Link and install it in the console Payload formater uplink.
Just copy & paste the content of the txt file and replace the existing payload formater demo in the thingsnetwork
Ulrich
