Dragon R1 - Open source RC car
Fully 3D printable RC racing car inspired by Roborace cars. Open Source design
Printables: https://www.printables.com/model/240045-dragon-r1-open-source-rc-car
Fusion 360 files: https://a360.co/3RFnxWf
Features of this Open Source car:
  • Maximum 3D printed parts
  • Easy to source hardware
  • Simple Assembly
  • Easy maintenance and battery access
  • Dual wishbone suspension
  • Open differential
  • Low noise drive (using Blheli ESC)
  • Printable with a 200mm size printer
Model is 1/12 scale;
  • length: 396mm
  • width: 164mm
  • height: 71mm
  • 6 × 608 bearing Commonly used as Skate ball bearings
  • 35 × M3 8mm screw
  • 22 × M3 12mm screw
  • 4 × M3 16mm screw
  • 10 × M3 20mm screw
View all 12 components
  • 1
    Assembly
    The assembly process is divided into 3 main parts:
    1) Rear chassis
    • Rear axle
    • Differential
    • Rear Suspension
    2) Front chassis
    • Steering mechanism
    • Front suspension
    3) Body assembly
    • Base chassis
    • Body
View all instructions
Juan Gabriel Vazquez wrote 07/30/2022 at 23:33 point
Awesome design, minimalistic, almost everithing 3d printed!!! Thanks for sharing!!!!
