Hackaday.io Hackaday.io
Sign up Log in
Climate Resilient Communiti - Power Cube
An attempt at the Climate Resilient Community challenge, featuring a self-powered Pi or ESP in a compact cube design.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.3k views
0 comments
1.8k followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 1
    • View all
  • Logs 15
    • View all
  • Instructions 0
  • Discussion 0
  • Supplyframe DesignLab: 2022 Hackaday Prize
View Gallery
1.3k
0
1.8k
16
Team (1)
  • tanguyTanguy
Join this project's team
MISC
ongoing project
solar cube cubesat energie self-powered Climate Resilient Communiti computer raspberry pi 2022hackadayprize
Related lists
Just Cubes
It rolls down stairs alone or in pairs, it's cube!
This project is submitted for
  • Climate Resilient Communities
This project was created on 07/18/2022 and last updated 2 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
This is my attempt at the Climate Resilient Community challenge, using a self-powered Pi or ESP in a cube. The goal is to create a cheap self-powered small computer (like a Raspberry Pi), or if power isn’t sufficient, an ESP. I took inspiration from the design of CubeSats, the micro-satellites.
Files
FullCube.STEP
step - 682.58 kB - 07/03/2024 at 09:54
Download
SingleFace.STEP
step - 409.82 kB - 07/03/2024 at 09:54
Download
link.STL
Link part to assemble the 6 faces into a cube shape
Standard Tesselated Geometry - 1.73 MB - 07/03/2024 at 09:27
Download
Components
  • 24 × 6v 0.5w Solar panels (x4 by faces) https://fr.rs-online.com/web/p/panneaux-solaires/1793740?searchId=4c3790b5-ace9-4025-be7c-09f6796eb4db&gb=s
Project Logs
Collapse
  • All sides
    Tanguy • 08/16/2022 at 17:34 • 2 comments
  • Make a cube
    Tanguy • 08/12/2022 at 12:58 • 0 comments
  • Glue and solder
    Tanguy • 08/10/2022 at 11:31 • 0 comments
  • PCBs are here !
    Tanguy • 08/08/2022 at 14:05 • 0 comments
  • Receive more of this
    Tanguy • 08/02/2022 at 15:29 • 0 comments
  • Test PCB pannel
    Tanguy • 08/01/2022 at 07:41 • 0 comments
  • Ok.. i'm gonna give up on the resin
    Tanguy • 07/29/2022 at 10:51 • 0 comments
  • Wish me luck
    Tanguy • 07/23/2022 at 13:43 • 0 comments
  • WIP & tests
    Tanguy • 07/22/2022 at 11:22 • 0 comments
    I made two, to try resin on one
    4x6v = 24v
  • Let's try something else (6v 0.5w mini panel)
    Tanguy • 07/21/2022 at 10:35 • 0 comments
View all 15 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A 3d printed enclosure to house multiple Pis
Project Owner Contributor
Raspberry Pi Rack
dave-peduDave Pedu
A 3d printed enclosure to house multiple Pis, updated for the Raspberry Pi 4
Raspberry Pi Rack for the Pi 4
dave-peduDave Pedu
A Raspberry pi based simple, functional, and multi-tasking cyberdeck optimized for outdoor adventures.
HAMDECK CYBERDECK
kaushlesh-c-kd9vfuKaushlesh C. ( KD9VFU )
WIZnet W5500 + RaspberryPI5 PoE+
Raspberry Pi 5 + PoE
alanAlan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Climate Resilient Communiti - Power Cube", please tell us the reason.
Send message
Remove Member
