After decades of frustration with shower curtain rings coming undone, breaking, not being filled with helium, or not being Diane Sawyer ear rings, there's real momentum behind this idea. As usual, the designs on the internet all suck.
Printed a full set over 3 hours. They also work as ear rings.
The flat shower ring design means that friction is going to slowly wear away the plastic when you pull it. The most force is going to go onto the edge instead of being distributed. This is why rings should be rounded.
