# download mps compilers
brew tap tgtakaoka/mspgcc
# prepare folders
sudo mkdir /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include
sudo chown -R $(whoami) /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include
# run install
brew install libc-msp430 gdb-msp430
https://exfil.co/2016/02/11/goodfet-on-os-x/
Found a good starting point to talk with the MSP430, but sadly it runs into a weird bootloader password issue.
goodfet.bsl -P ./goodfet.hex --fromweb Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Traceback (most recent call last): File "/usr/local/bin/goodfet.bsl", line 1987, in main(0); File "/usr/local/bin/goodfet.bsl", line 1887, in main bsl.actionStartBSL() File "/usr/local/bin/goodfet.bsl", line 1166, in actionStartBSL self.txPasswd(self.passwd) #transmit password File "/usr/local/bin/goodfet.bsl", line 1136, in txPasswd wait=wait) #if wait is 1, try to sync forever File "/usr/local/bin/goodfet.bsl", line 801, in bslTxRx rxFrame = self.comTxRx(cmd, dataOut, len(dataOut)) #Send frame File "/usr/local/bin/goodfet.bsl", line 480, in comTxRx rxHeader, rxNum = self.comRxHeader() #receive header File "/usr/local/bin/goodfet.bsl", line 386, in comRxHeader if not hdr: raise BSLException("Timeout") __main__.BSLException: Timeout
aha! So the tutorial uses a capital P where the flag should be a small p. Or not, maybe the password stuff is set somewhere else or while compiling. writing the ./prebuilt firmware worked.
board=goodfet42 goodfet.bsl -p goodfet.hex
Well that wasn't really a solution, but somehow I got it to except the firmware, probably by using the "fromweb" flag for it, where it wasn't confused by all that.
