trying to get the GoodFET running on mac
08/05/2022 at 11:30 • 4 comments# download mps compilers brew tap tgtakaoka/mspgcc # prepare folders sudo mkdir /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include sudo chown -R $(whoami) /opt/homebrew/lib/msp430 /opt/homebrew/lib/msp430/lib /opt/homebrew/include/msp430 /opt/homebrew/include/msp430/include # run install brew install libc-msp430 gdb-msp430
https://exfil.co/2016/02/11/goodfet-on-os-x/
Found a good starting point to talk with the MSP430, but sadly it runs into a weird bootloader password issue.
goodfet.bsl -P ./goodfet.hex --fromweb Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Use -h for help Use --fromweb to upgrade a GoodFET. MSP430 Bootstrap Loader Version: 1.39-goodfet-8 Invoking BSL... Transmit password ... Traceback (most recent call last): File "/usr/local/bin/goodfet.bsl", line 1987, in main(0); File "/usr/local/bin/goodfet.bsl", line 1887, in main bsl.actionStartBSL() File "/usr/local/bin/goodfet.bsl", line 1166, in actionStartBSL self.txPasswd(self.passwd) #transmit password File "/usr/local/bin/goodfet.bsl", line 1136, in txPasswd wait=wait) #if wait is 1, try to sync forever File "/usr/local/bin/goodfet.bsl", line 801, in bslTxRx rxFrame = self.comTxRx(cmd, dataOut, len(dataOut)) #Send frame File "/usr/local/bin/goodfet.bsl", line 480, in comTxRx rxHeader, rxNum = self.comRxHeader() #receive header File "/usr/local/bin/goodfet.bsl", line 386, in comRxHeader if not hdr: raise BSLException("Timeout") __main__.BSLException: Timeout
aha! So the tutorial uses a capital P where the flag should be a small p. Or not, maybe the password stuff is set somewhere else or while compiling. writing the ./prebuilt firmware worked.
board=goodfet42 goodfet.bsl -p goodfet.hex
Well that wasn't really a solution, but somehow I got it to except the firmware, probably by using the "fromweb" flag for it, where it wasn't confused by all that.
but first, we must build a goodFET42
07/18/2022 at 19:44 • 0 commentsSure, I could try and do the same hard work that plenty people have done before me, do miserably and fail - or I could just try and get stuff from back then working. So within chip shortage I tried to get hold of the MSP chip that's featured on the GoodFET, a DIY JTAG and more probe, that isn't obtainable anywhere. Thankfully everything I needed was accessible and so I started redesigning the GoodFET in KiCad, swapped some parts and added rounded corners basically and ordered the boards at OSHpark. Why did I do that? Because all the tutorials from 2010 basically start with "connect your GoodFET to the im-me messenger" and well I need one then, of course.
