Configuring user project with STM32CubeMX code generator to use MIDI Device Class Middleware
In STM32CubeMX / STM32CubeIDE:- At USB → enable Device FS
- At USB_DEVICE → choose Human Interface Device Class (HID)
- Generate code
To use MIDI Device Class middleware, project requires few modifications in generated code:
- Copy usbd_midi.c and usbd_midi.h to Middlewares/ST/STM32_USB_Device_Library/Class/MIDI/ Src and Inc folders respectively.
- In your IDE add those folders to C/C++ compiler include path, and files to corresponding group.
- Modify USB_DEVICE/App/usb_device.c:
#include "usbd_hid.h" // replace this line
#include "usbd_midi.h" // with this line
if (USBD_RegisterClass(&hUsbDeviceFS, &USBD_HID) != USBD_OK) // replace this line
if (USBD_RegisterClass(&hUsbDeviceFS, &USBD_MIDI) != USBD_OK) // with this line
- Modify USB_DEVICE/Target/usbd_conf.c:
/* USER CODE BEGIN EndPoint_Configuration_HID */ // You may replace HID with MIDI for more convenience, but code generator will not keep it on next code generate
HAL_PCDEx_PMAConfig((PCD_HandleTypeDef*)pdev->pData , 0x01 , PCD_SNG_BUF, 0xC0); // add this line
HAL_PCDEx_PMAConfig((PCD_HandleTypeDef*)pdev->pData , 0x81 , PCD_SNG_BUF, 0x100); // leave this line as is
/* USER CODE END EndPoint_Configuration_HID */
static uint32_t mem[(sizeof(USBD_HID_HandleTypeDef)/4)+1]; // replace this line
static uint32_t mem[(sizeof(USBD_MIDI_HandleTypeDef)/4)+1]; // with this line
- Modify Core/Inc/main.h:
/* USER CODE BEGIN EM */
#define MIDI_IN_PORTS_NUM 0x01 // Specify input ports number of your device
#define MIDI_OUT_PORTS_NUM 0x03 // Specify output ports number of your device
Send midi messages packet to host device:
- Ensure that MIDI driver status is IDLE by:
USBD_MIDI_GetState(&hUsbDeviceFS) == MIDI_IDLE
- Send midi messages packet with:
USBD_MIDI_SendReport(&hUsbDeviceFS, messagesBuffer, MIDI_EPIN_SIZE);
Receive midi messages packet from host device:
- Implement this weak function with something like this:
void USBD_MIDI_DataInHandler(uint8_t *usb_rx_buffer, uint8_t usb_rx_buffer_length) { while (usb_rx_buffer_length && *usb_rx_buffer != 0x00) { wire = usb_rx_buffer[0] >> 4; message = usb_rx_buffer[1] >> 4; channel = usb_rx_buffer[1] & 0x0F; messageByte1 = usb_rx_buffer[2]; messageByte2 = usb_rx_buffer[3]; usb_rx_buffer += 4; usb_rx_buffer_length -= 4; } }
Wonderful code. i follow your step, and then generate code, but I can't find the two files : usbd_midi.c and usbd_midi.h. And the directory is "Middlewares\ST\STM32_USB_Device_Library\Class\HID" instead of "Middlewares/ST/STM32_USB_Device_Library/Class/MIDI/", can you help me , thank you very much!
