Print Speed Test
A project log for DuePrint
This is a Stratasys Uprint SE+ 100 percent reversible, open source retrofit controlled by a Duet3D Duet 2 wifi, DueX5 and Geckodrive G320X.
jeremyJeremy 07/22/2022 at 00:540 Comments
Print Speed Test Results. 0.2 mm layer height, initial print speed 90 mm/s, increasing print speed observed resulting in what is likely acceleration limited print speed for most of the print at print speed setting of 240 mm/s. Minimal print vibrations observed. The extruder can out extrude the print movements!
