I have been working a few years to design and build a practical, efficient variable capacitor for amateur radio loop antenna. The goal is to use 3D printing and easily available parts. See my other projects: the HF short loop antennas and the easy-peasy high voltage variable capacitor. They provide a background for this project.
This project is complete. It works very well and is my primary portable antenna. See the photos. I have not written it up yet as a step-by-step project.
A loop antenna will provide greater reception for your devices and will improve your performance in weak signal areas. If you live in a remote area with many dead spots then the gain from loop antennas can be amazing. So go now and get more information
如果您居住在比较偏远的山村,那么环形光缆的作用会非常惊人,<a href="https://www.baudcom.com.cn">现在</a>
您可以获取<a href="https://www.e1-converter.com/product.html">更多</a>信息
