one board is soldered
A project log for Nokia 3310 / 5110 display board
had to extract it from the game boy programmer / cartridge project
davedarkodavedarko 01/25/2017 at 23:075 Comments
Notes:
Alex wrote 01/26/2017 at 17:34 point
Nice!
deʃhipu wrote 01/26/2017 at 12:55 point
It's pretty bad when your buck converters give you bang.
davedarko wrote 01/26/2017 at 13:08 point
yeah, but when you forget that for 3V3 you have to connect some pads first to make it work ... then I really don't see the point in it at all. If some people still uses 5V boards than they should buy some cheap converters on eBay or something :)
Eric Hertz wrote 01/26/2017 at 11:15 point
That backlighting is pretty slick. Did you use regular smt LEDs or did they have to be right-angle?
davedarko wrote 01/26/2017 at 11:35 point
regular 0603 / 0606 smd rgb leds, I think they mostly reflect on the metal case, they shoot straight up into the plastic, but it looks even better in real life :)
