11. LoRaWAN and IoT Connection
A project log for Environmental Toolkit for an Ecological Area
LoRaWAN IoT system with the Arduino MKR WAN 1300, that help my community to monitor the air quality and water of our ecological area
guillermo-perez-guillenGuillermo Perez Guillen 07/26/2022 at 21:160 Comments
LORAWAN TRANSMITTER
Below I show you the schematic diagram of the transmitter with multiple sensors.
Below I show you the code used to upload it to the Arduino MKR WAN 1300 transmitter board.
LoRaSender_v5.ino
// AUTHOR: GUILLERMO PEREZ GUILLEN
#include <SPI.h> // LoRa->
#include <LoRa.h>
#include <OneWire.h> // DS18B20->
#include <DallasTemperature.h>
#include <Wire.h> // LCD->
#include "rgb_lcd.h"
rgb_lcd lcd;
const int colorR = 173;
const int colorG = 255;
const int colorB = 47;
#include "DHT.h" // DHT22 ->
#define DHTPIN 3    // Pin where the sensor is connected
#define DHTTYPE DHT22   // DHT22 sensor
DHT dht(DHTPIN, DHTTYPE);
// DS18B20-> Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
#define anInput     A0 // MQ135-> analog feed from MQ135
int counter = 0;
void setup() {
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setRGB(colorR, colorG, colorB);
  lcd.print("ECOLOGY!");
  pinMode(anInput,INPUT); // MQ135
  lcd.setCursor(0, 1); // LCD
  lcd.print("LoRa Sender");
  if (!LoRa.begin(915E6)) {
  lcd.print("Starting LoRa failed!");
    while (1);
  sensors.begin();   //temperature sensor starts
  dht.begin();
void loop() {
  int co2now[10]; //int array for co2 readings
  int co2raw = 0; //int for raw value of co2
  int co2ppm = 0; //int for calculated ppm
  int zzz = 0; //int for averaging
  for (int x = 0;x<10;x++) // MQ135-> samplpe co2 10x over 2 seconds
    co2now[x]=analogRead(A0);
    delay(200);
  for (int x = 0;x<10;x++) // add samples together
    zzz=zzz + co2now[x];
  co2raw = zzz/10; // divide samples by 10
  co2ppm = co2raw;
  int h = dht.readHumidity(); //We read the Humidity
  sensors.requestTemperatures();   //The command to read the temperature is sent
  int temp = sensors.getTempCByIndex(0); //The temperature is obtained in ยบC
  // send packet
  LoRa.beginPacket();
  LoRa.print(temp);
  LoRa.print(",");
  LoRa.print(h);
  LoRa.print(",");
  LoRa.print(co2ppm);
  LoRa.endPacket();
  lcd.clear();
  lcd.setCursor(0, 0); // LCD
  lcd.print("P=");
  lcd.setCursor(3, 0); // LCD
  lcd.print(counter);
  lcd.setCursor(8, 0); // LCD
  lcd.print("T=");
  lcd.setCursor(11, 0); // LCD
  lcd.print(temp);
  lcd.setCursor(14, 0); // LCD
  lcd.print("C");
  lcd.print("H=");
  lcd.setCursor(3, 1); // LCD
  lcd.print(h);
  lcd.setCursor(6, 1); // LCD
  lcd.print("%");
  lcd.setCursor(8, 1); // LCD
  lcd.print("CO2=");
  lcd.setCursor(13, 1); // LCD
  lcd.print(co2ppm);
  counter++;
  delay(13000);
LORAWAN RECEIVER
Below I show you the schematic diagram of the receiver. device
Below I show you the code used to upload it to the Arduino MKR WAN 1300 receiver board.
LoRaReceiver_v5.ino
#include <SPI.h>
#include <LoRa.h>
#include <Arduino.h>   // SERCOM1
#include "wiring_private.h" // SERCOM1
// SERCOM1: Rx->D9 & Tx->D8
Uart Serial3 (&sercom1, 9, 8, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM1_Handler()
  Serial3.IrqHandler();
#include <Wire.h> // Library for I2C communication
#include <LiquidCrystal_I2C.h> // Library for LCD
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4); // Change to (0x27,16,2) for 16x2 LCD.
char cadena[30]; //We create an array that will store the characters that we will write in the PC console. We assign a limit of characters, in this case 30
byte posicion=0;  //Variable to change the position of the characters in the array
int valor;  //Integer Variable
void setup() {
  lcd.init();  // Initiate the LCD:
  lcd.backlight();
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(9600);
  Serial3.begin(9600); // SERCOM1
  // Assign pins 8 & 9 SERCOM1 functionality
  pinPeripheral(8, PIO_SERCOM);
  pinPeripheral(9, PIO_SERCOM);
  Serial.println("LoRa Receiver")
    Serial.println("Starting LoRa failed!");
    while (1);
void loop() {
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    memset(cadena, 0,sizeof(cadena));//memset deletes the contents of the array "cadena" from position 0 to the end sizeof
    // received a packet
    Serial.print("Received packet... ");
    // read packet
    while (LoRa.available()) {
      char dedos= (char)LoRa.read();
      Serial.print(dedos);
      Serial3.print(dedos);
      cadena[posicion]=dedos;//Read a character from the string "cadena" from "posicion", then read the next character with "posicion++"
      posicion++;
    posicion=0;
    int signal_rx = LoRa.packetRssi();
    // print RSSI of packet
    Serial.print(" with RSSI ");
    Serial.println(signal_rx);
    int parte1 = getValue(cadena,',',0).toInt();
    int parte2 = getValue(cadena,',',1).toInt();
    int parte3 = getValue(cadena,',',2).toInt();
    Serial.println(parte1);
    delay(100);
    Serial.println(parte2);
    delay(100);
    Serial.println(parte3);
    delay(100);
    lcd.clear();
    lcd.print("RSSI =");
    lcd.setCursor(7, 0);
    lcd.print(signal_rx);
    lcd.print("dBm");
    lcd.print("Temp =");
    lcd.print(parte1);
    lcd.setCursor(11, 1);
    lcd.print("C");
    lcd.setCursor(0, 2);
    lcd.print("Hum =");
    lcd.setCursor(8, 2);
    lcd.print(parte2);
    lcd.setCursor(11, 2);
    lcd.print("%");
    lcd.setCursor(0, 3);
    lcd.print("CO2 =");
    lcd.setCursor(8, 3);
    lcd.print(parte3);
    lcd.setCursor(11, 3);
    lcd.print("PPM");
    digitalWrite(LED_BUILTIN, HIGH);
    delay(2000);
    digitalWrite(LED_BUILTIN, LOW);
    delay(12000);
String getValue(String data, char separator, int index)
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length()-1;
  for(int i=0; i<=maxIndex && found<=index; i++){
    if(data.charAt(i)==separator || i==maxIndex){
        found++;
        strIndex[0] = strIndex[1]+1;
        strIndex[1] = (i == maxIndex) ? i+1 : i;
  return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
IOT CONNECTION TO THE THINGSPEAK PLATFORM
Finally, below I show you the code to program the Arduino NANO 33 IoT board. this code processes the three sensors information and sends it to the ThingSpeak IoT platform.
Nano33Iot_Multiple_Sensors.ino
#include <WiFiNINA.h> // THINGSPEAK->
#include "secrets.h"
#include "ThingSpeak.h"
char ssid[] = SECRET_SSID;    //  your network SSID (name)
char pass[] = SECRET_PASS;   // your network password
int keyIndex = 0;            // your network key Index number (needed only for WEP)
WiFiClient  client;
unsigned long myChannelNumber = SECRET_CH_ID;
const char * myWriteAPIKey = SECRET_WRITE_APIKEY;
void setup()
  Serial.begin(9600);
  Serial1.begin(9600);
  // THINGSPEAK-> check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv != "1.0.0") {
    Serial.println("Please upgrade the firmware");
  ThingSpeak.begin(client);  //Initialize ThingSpeak
void loop()
  // THINGSPEAK-> Connect or reconnect to WiFi
  if(WiFi.status() != WL_CONNECTED){
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(SECRET_SSID);
    while(WiFi.status() != WL_CONNECTED){
      WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using open or WEP network
      Serial.print(".");
      delay(5000);
    Serial.println("\nConnected.");
  if(Serial1.available()) //Is there data inside the buffer?
    while(Serial1.available()>0) //As long as there is data in the buffer execute the function
      delay(5);
      cadena[posicion]=Serial1.read();//Read a character from the string "cadena" from "posicion", then read the next character with "posicion++"
      posicion++;
    posicion=0;
    // Write to ThingSpeak. There are up to 8 fields in a channel, allowing you to store up to 8 different
    // pieces of information in a channel.  Here, we write to field 1.
    delay(100);
    delay(100);
    delay(100);
    // set the fields with the values
    ThingSpeak.setField(1, parte1);
    ThingSpeak.setField(2, parte2);
    ThingSpeak.setField(3, parte3);
  // write to the ThingSpeak channel
  int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
  if(x == 200){
    Serial.println("Channel update successful.");
  else{
    Serial.println("Problem updating channel. HTTP error code " + String(x));
    delay(15000);
  int found = 0;
        found++;
Don't forget to type the corresponding credentials to connect to the IoT provider. In the download section you can get the "secrets.h" file.
// and connection details
#define SECRET_SSID "*********"        // replace MySSID with your WiFi network name
#define SECRET_PASS "************"    // replace MyPassword with your WiFi password
#define SECRET_CH_ID *******            // replace ******* with your channel number
#define SECRET_WRITE_APIKEY "****************"   // replace **************** with your channel write API Key
