Jenny-XJ9
A small form factor PC built inside Cooler Master NR200P
Custom LAN Party SFFPC
Won an neat AIO liquid cooler at a LAN Party as a prize, gonna build a mini computer with it.
  • 1 × NR200P Case https://www.amazon.com/gp/product/B096L2BLNR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • 1 × MasterLiquid PL240 Flux AIO Cooler https://www.amazon.com/Cooler-Master-MasterLiquid-Chamber-Enlarged/dp/B09PWHJ19J
  • 1 × Sapphire RX 580 Nitro+ 8GB GPU
  • 2 × Noctua Redux 120mm Fan https://www.amazon.com/Noctua-redux-1700-high-Performance-Award-Winning-Affordable/dp/B07CG2PGY6
  • Officially Entered IN Cooler Master's Contest
    STEAL-THIS-HARDWARE08/02/2022 at 21:12 0 comments
    Officially Entered in the modding contest, another update will follow where I show of the paint here but check it out early here
    https://worklogs.coolermaster.com/topic/29023-xj9-jenny-a-small-form-factor-pc-mod-inspired-by-a-cartoon-for-lan-party-action/
  • Inverted and Flipped !​
    STEAL-THIS-HARDWARE08/01/2022 at 04:47 0 comments
    Inverted and Flipped ! Top mount radiator is the best case for AIO coolers so I am fixing the engineering mistake the CM fixed with their more expensive version of this case thats never in stock LMFAO
    First invert modular parts and remove non essentials
    Next Get the drill
    Dissassemble
    Marked for drilling
    Grandpa's drill press still making my dreams come true today !
    Rivet and reassemble
    WE don't run anything stock in this house, now will the rest of the shit fit ? stay tuned  ;)
  • NR200P Arrived In The Mail and Scythe Fans
    STEAL-THIS-HARDWARE07/31/2022 at 05:07 0 comments
    So I got the case in the mail and its pretty damn small, especailly compared to my Corsair 7000D and even to an old mATX Lian Li case I have like wow SFFPCs are crazy.
    Its pretty fantastic in terms of build quality/features I'm pretty impressed out of  box its gonna hurt to drill out the rivets, file, and flip it. Though I might be able to get way without doing that, Found some new fans from Scythe that boast impressive specs and are much thinner, going to have to order some to see if they fit.
  • Welp Looks Like I'm Doing That SFFPC Afterall !
    STEAL-THIS-HARDWARE07/29/2022 at 22:59 0 comments
    Hey folks !!!
    So last year into early this year I build a new desktop workstation, which resulted in some leftover parts after some tweaking and GPUs magically becoming available to me locally at the very end of 2021. So I have some left over parts to work with but wait there's more!! I attended a LAN Party with friends and took hom a Cooler Master MasterLiquid PL240 Flux AIO Liquid cooler.
    Feeling the excitement and hearing the plans for the next LAN Party happening int he fall, I decided then and there to do an SFFPC with this cooler and my leftover parts.
    I will be using the Cooler Master Masterbox NR200P DTX/ITX case but in true fashion with this page and community I will be voiding the warranty day one, drilling out the rivet so I can invert the entire case for top mount radiator !!!
    Stay tuned !
View all 4 project logs
