Finally printed
A project log for Microscope fiber optic lighting rig (version 2)
Custom lighting for a inverted microscope to successfully photograph and analyze non transparent macro objects using fiber optic wire.
zachary-marlowZachary Marlow 08/08/2022 at 03:180 Comments
Finally got the resin prints all done and they came out perfect and the MAGNETS FIT!!!!!, now I just need to let them cure and get a sample mounted. I just wanted to post an update because I've been putting off this print because resin printers are smelly and I don't like stinking up my house but I finally pulled the trigger. With a little bit of luck I will have some cool macro photos and showing off the project at its fullest.
