More parts, more f***ups
A project log for Mr Pancake
Making a pancake printer with no planning ahead whatsoever
nikolai-ovesenNikolai Ovesen 12/08/2016 at 14:150 Comments
Got one of the two mounting brackets for the second axis printed and test fitted, works like a charm, only after assembling it I realized that I'd either have to mount the motor and belt sprockets for the x axis infront of the mounts for the x axis or redo the belt attachment/ball bearing brackets for the rods as it does not have enough clearance.... time will show what I figure out...
