LRMS MPPT Solar Power Module - Test and Characterization
A project log for LoRa End Node & Remote Monitoring System
A LoRa remote solar powered monitoring system designed to be as flexible as possible and connect to a variety of sensors/sensor modules
jstuartjstuart 09/25/2022 at 03:340 Comments
R1  used with a INA3221 voltage and current monitor as a prototype model for revision 2.
Prototype for revision 2:
Weather conditions:
2022/09/22 : Sunny with occasional high thin clouds
2022/09/23 : Early morning thin overcast followed Sun with intermittent cloud coverage
Solar Panel Configuration:
Orientation: South
Latitude: 48°4’41”N
Panel Angle: 50 degrees
Panel Width: 221mm
Panel Length :257mm
MPPT Solar Power Module:
Battery : 2500mAh 3.7V LiPO 1S cell
MPPT Charge Current : 200 mA
Charge Control Termination: C/10
MPPT LiPO Cell maximum charge level : 4.15V
Boost Converter Efficiency :
3.3 Vin 6.0 Vout I_Load 10mA 80 percent
3.3 Vin 6.0 Vout I_Load 200mA 85 percent
4.2Vin 6.0 Vout I_Load 200mA 80> percent
4.2Vin 6.0 Vout I_Load 200mA 90> percent
Load Current : 20mA
V_Batt Load Voltage : 5.832V
Solar Panel : Voltaic Systems P109 6Volt 9 Watt
Panel Ratings
Nominal
Expected
Open-Circuit Voltage
Voc
7.67
7.28
V
Voltage at Max Power
Vp
6.50
6.18
V
Short-Circuit Current
Isc
1.56
1.50
A
Current at Max Power
Ip
1.46
1.39
A
Maximum Power
Wp
9.49
8.56
W
2022-09-23 07:20:50 : Battery level 3.872 V
2022-09-23 10:10:24 : 4.144 V
