Better sleep
A project log for M0S - CortexM0 RTOS in 1024 bytes
Full blown RTOS written in Thumb ARM assembly language to fit in 1024 bytes
dumitrustamadumitru.stama 12/02/2016 at 03:582 Comments
I replaced the infinite loop in the idle task with "wfi" instruction. Theoretically this should put the processor to sleep until the next systick interrupt and this will save energy. I said theoretically because it needs some setup but it seems to work out of the box so I will keep it as an option.
I also uploaded the RAM memory map.
dumitru.stama wrote 12/02/2016 at 08:05 point
Since this is a proof of concept I will probably not spend too much time on this. I just noticed some stability issues with the "janitor idle task" so I reverted to an infinite loop until I re-write.
K.C. Lee wrote 12/02/2016 at 04:50 point
Wfi save very little power on regular M0, but it is still better than nothing.
