Today in this tutorial we are going to make a simple "ESP8266 Weather Station with BME280".
This electronic project uses ESP8266 ESP01 as the control device that easily connects to the existing WiFi network & creates a Web Server. When any connected device accesses this web server, ESP8266 reads in temperature, humidity, barometric pressure & altitude from BME280 & sends it to the web browser of that device with a nice interface. Excited? Let’s get started!
The BME280 sensor uses I2C or SPI communication protocol to exchange data from Microcontroller. BME280 is simple & easy to use, pre-calibrated and doesn’t require any extra components to run. You can simply start measuring relative humidity, temperature, barometric pressure & approximated altitude in no time
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware Components
S.NoComponentsValueQty
1ESP01
2BME280 Sensor
3SMD Resistors10K1
4SMD Button1
Circuit Diagram
Here we use I2C communication with the BME280 sensor module. For that, wire the sensor to the ESP8266 SDA and SCL pins, as shown in the following schematic diagram. SDA to D1 and SCL to D2.
ESP8266 Weather Station Code
#include <ESP8266WebServer.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
float temperature, humidity, pressure, altitude;
/*Put your SSID & Password*/
const char* ssid = "Circuits DIY";  // Enter SSID here
const char* password = "03433212601";  //Enter Password here
ESP8266WebServer server(80);               void setup() {  Serial.begin(115200);  delay(100);    bme.begin(0x76);     Serial.println("Connecting to ");  Serial.println(ssid);
  //connect to your local wi-fi network  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network  while (WiFi.status() != WL_CONNECTED) {  delay(1000);  Serial.print(".");  }  Serial.println("");  Serial.println("WiFi connected..!");  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  server.on("/", handle_OnConnect);  server.onNotFound(handle_NotFound);
  server.begin();  Serial.println("HTTP server started");
void loop() {  server.handleClient();
void handle_OnConnect() {  temperature = bme.readTemperature();  humidity = bme.readHumidity();  pressure = bme.readPressure() / 100.0F;  altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);  server.send(200, "text/html", SendHTML(temperature,humidity,pressure,altitude)); }
void handle_NotFound(){  server.send(404, "text/plain", "Not found");
String SendHTML(float temperature,float humidity,float pressure,float altitude){  String ptr = "<!DOCTYPE html> <html>\n";  ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";  ptr +="<title>ESP8266 Weather Station</title>\n";  ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";  ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;}\n";  ptr +="p {font-size: 24px;color: #444444;margin-bottom: 10px;}\n";  ptr +="</style>\n";  ptr +="</head>\n";  ptr +="<body>\n";  ptr +="<div id=\"webpage\">\n";  ptr +="<h1>ESP8266 Weather Station</h1>\n";  ptr +="<p>Temperature: ";  ptr +=temperature;  ptr +="°C</p>";  ptr +="<p>Humidity: ";  ptr +=humidity;  ptr +="%</p>";  ptr +="<p>Pressure: ";  ptr +=pressure;  ptr +="hPa</p>";  ptr +="<p>Altitude: ";  //ptr +=altitude;  ptr +="m</p>";  ptr +="</div>\n";  ptr +="</body>\n";  ptr +="</html>\n";  return ptr;
