Today was just some light weight stuff. Added EM isolation tape and kapton to all the bundles of the power supply and rerouted the power cables a little better. Did a little more work on the shaping of the case cover to get a better fit and get the lid to close air tight. Still need to lay out all the holes that need to be drilled and milled out of the base-plate
