I did the whole design based on using the 38 pin ESP DevKitC, though there are a lot of unused pins. I started wondering if someone could use the PCB with a 30 pin ESP DevKitC, with only software changes. The answer is "almost". The pin assignments in the software and in the physical PCB layout are in this project log entry: ESP32 pin assignments
My assumption is that any of the software-controlled inputs and outputs could be switch to another pin, modulo things like "input only" pins. I can't change things that aren't controlled by software: Vin 5v, 3.3v output, and ground pins. Many, but not all, of the signal pins line up nicely in the two footprints if you slide the 30 pin device down one notch. That is, pin 1 of the 30 pin device is placed in position pin 2 of the PCB footprint.
The 38 pin layout looks like this:
1 3.3v 38 gnd ---------------------------- 2 reset* 37 f4-pwr* 3 36 i2c-scl* 4 35 5 34 6 33 i2c-sda* 7 32 8 31 f4-tach** 9 f1-tach* 30 f4-pwm** 10 f2-tach* 29 11 f3-tach* 28 f2-pwm** 12 f1-pwr* 27 f1-pwm** 13 f3-pwr* 26 14 gnd* 25 15 f2-pwr 24 16 23 f3-pwm --------------------------- 17 22 18 21 19 Vin 5v 20
In that list, signals marked with a single asterisk means that they show up in the same GPIO on the (adjusted) position on the 30 pin device. (It can be a little confusing because not all of the GPIOs how up in the same relative positions. It's the GPIOs that are of interest.) Signals marked with 2 asterisks mean the corresponding pin isn't the same, but the signal can still be accommodated with a software re-arrangement. Signals with no asterisk means that something extra has to be done.
Here's the corresponding (adjusted) 30 pin layout:
1 reset 30 f4-pwr 2 29 i2c-scl 3 28 4 27 5 26 i2c-sda 6 25 7 24 change from f4-pwm to f4-tach 8 f1-tach 23 same as 29 (GPIO 5), as f4-pwm 9 f2-tach 22 10 f3-tach 21 change from f1-pwm to f2-pwm 11 f1-pwr 20 same as 26 (GPIO 4), as f1-pwm 12 f3-pwr 19 13 gnd 18 14 gnd 17 15 Vin 5v 16 3.3v
Here are the modifications needed to make this work:
- Software change to move GPIO signals as indicated
- Jumper from PCB pin 19 to PCB pin 16 for Vin 5v
- Special handling for f2-pwr and f3-pwm, described below.
The special handling for f2-pwr and f3-pwm is required because the corresponding pin on the 30 pin device is ground or 3.3v output. There's no way around it other than severing those signals and running a new f2-pwr and f3-pwm signals.
Luckily, there is an unrelated PCB option that can come to the rescue for f3-pwm. The signals for f2-pwm, f3-pwm, f4-pwm, f2-pwr, f3-pwr, and f4-pwr are routed to 3-pin jumper options. On the v4 board, there is a trace connecting pin 1 and pin 2 of each of those jumper options since that's the behavior that is usually wanted. That trace is on the top side of the board, not clearly visible under the solder mask and silk screen.
Unfortunately, the same jumper option trick can't be used for re-routing f2-pwr. The f2-pwr signal is a digital signal controlling a MOSFET transistor, and it's the output of that MOSFET that goes through the jumper option. There is an only semi-ugly hack that we can use. The digital signal controlling the MOSFET for f2-pwr passes through resistor R42. Instead of soldering both ends of that resistor to the PCB, solder only the lead nearer the MOSFET. The other lead, which would normally be soldered to a pad nearer the ESP32, can be left unsoldered as an attachment point for a jumper wire.
The complete fix would be:
- Software change to move f2-pwr and f3-pwm from current pins to some other available GPIO pins.
- Jumper from PCB pin 23 to PCB pin 1 to provide 3.3v output where needed.
- Cut the trace between pins 1 and 2 of PCB JP23 and JP12.
- Jumper between pin 2 of PCB JP23 to the new f3-pwm pin chosen above.
- Jumper the near end of R42 to the new f2-pwr pin chosen above.
I haven't tested this, but it should all work out unless I have made a mistake. Aside from software changes, which should be a trivial ESPHome config file edit, it's just 1 cut trace, one lifted resistor lead, and two "white wire" jumpers, which is not too bad. If I had been thinking about this from the beginning, I could have made the special handling of f2-pwr and f3-pwm unnecessary. Oh, well.
