Here are the general specifications:
✔️Cut-off frequency can be set between 50Hz-10kHz
✔️Buffered Input and output (high-impedance input, low impedance output)
✔️Can be directly powered with PlainDAQ (+/- bipolar supply)
✔️Cool, educational visuals.
✔️Can be controlled with PlainDAQ's GUI.
✔️Compatible with Qwiic connectors.
✔️Uses Digi-pot for cut-off frequency setting.
Components
1×
MCP45HV51
2×
TL071
Amplifier and Linear ICs / Operational Amplifiers
