Controlling a Tesla Coil Powered Nixie with Light Logic
A project log for Light Logic And Much More
Imagine Light Logic, Tesla Coils and Nixie display tubes combined
dr-cockroachDr. Cockroach 08/18/2022 at 13:210 Comments
August 18, 2022
Wow, a long title but it says it all so let's dive right into it. I take a wire and loose couple it near the secondary of the Tesla Coil. That wire feeds high voltage to the anode of the nixie tube. The tube cathodes are switched by the output of the Light Logic sequencer.  There is still a lot of work and investigation to do but this set-up does prove enough to me that it works. The digits in the video flash by quickly so appear blurred but the digits are cycling 0 through 6.
The blurring is also being caused by the CdS cells do not completely stop the path of the HV RF in the circuit so the digits not selected tend to glow a bit. I am already looking into adding a relay in the control circuit.
