First pixels
A project log for PIC Graphics Demo
Generate 640x480 64-color VGA graphics with an 8-bit PIC and an SRAM framebuffer
ted-yapoTed Yapo 01/02/2017 at 00:020 Comments
After a little probing with the scope, I figured out how to program this thing. So far, just big, ugly boring yellow and magenta. I've used 364 bytes of my 1 kB - hopefully there is enough room left to do something cool. I guess I could always move to assembly, too - if I have to...
The vertical back porch is 80ns longer than it should be due to the way the counter reset logic works - there's essentially a "branch delay slot" at the end of the frame when the counter needs to be reset. Nobody cares if the 1+ ms back porch is off by this much. Otherwise, the 640x480 output should be exactly by-the-book. With some extra code, I could compensate and make the back porch exact, too, but it probably is not worth the effort (and precious instruction space).
I made a few subtle changes to the design as I built it; I'll post a full updated schematic once I put this thing through a few more tests.
Here's the code so far. Mostly bitbanging the SRAM to jam the waveforms in. Now, I have to make something flashy. Maybe I'll play ouside the box a little and use all my 28 kB code space for something cool but not contest-related :-)
// vga_test.c - create first VGA frame
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <pic16f1718.h>
// CONFIG1
#pragma config FOSC = INTOSC
#pragma config WDTE = OFF
#pragma config PWRTE = ON
#pragma config MCLRE = ON
#pragma config CP = OFF
#pragma config BOREN = ON
#pragma config CLKOUTEN = OFF
#pragma config FCMEN = ON
// CONFIG2
#pragma config WRT = ALL
#pragma config PPS1WAY = OFF
#pragma config ZCDDIS = ON
#pragma config PLLEN = ON
#pragma config STVREN = OFF
#pragma config BORV = LO
#pragma config LPBOR = OFF
#pragma config LVP = ON
// h/w interface definition
#define REG_OE_bar 0b00010000
#define WE_bar     0b00000001
#define OE_bar     0b00000010
#define CP_en      0b00001000
#define MR_en      0b00100000
#define CP_bar     0b00000100
#define MR_bar     0b00010000
#define VSYNC 0b10000000
#define HSYNC 0b01000000
#define RGB(r, g, b) (((r & 0x3) << 4) | ((g & 0x3) << 2) | (b & 0x3))
void SetupPeripherals() {
  // intosc 32 MHz
  OSCCON = 0b11110000;
  // select digital I/O
  ANSELA = 0;
  ANSELB = 0;
  ANSELC = 0;
  // set TRIS bits: all outputs
  PORTA = 0x00;
  TRISA = 0x00;
  PORTB = 0x00;
  TRISB = 0x00;
  PORTC = 0x00;
  TRISC = 0x80;
// set control lines for free-running VGA signal generation
void RunMode()
  TRISC = 0xff; // data lines all inputs
  // reset address counter, then let it rip
  LATB = WE_bar | OE_bar&0 | CP_en&0 | CP_bar&0 | MR_en   | MR_bar   ;
  LATB = WE_bar | OE_bar&0 | CP_en&0 | CP_bar&0 | MR_en&0 | MR_bar&0 ;
  LATA = REG_OE_bar&0;
// set control lines for bitbanging waveforms into SRAM, and
//   reset SRAM address counter to 0
void LoadMode()
  LATA = REG_OE_bar;
  // toggle CP with MR low to reset address counter
  LATB = WE_bar | OE_bar | CP_en | CP_bar   | MR_en | MR_bar   ;
  LATB = WE_bar | OE_bar | CP_en | CP_bar&0 | MR_en | MR_bar   ;
  // bring out of reset
  LATB = WE_bar | OE_bar | CP_en | CP_bar   | MR_en | MR_bar&0 ;
  TRISC = 0x00; // data lines all outputs
// bitbang a number of identical bytes into sequential SRAM addresses
void write_SRAM_bytes(uint8_t value, uint8_t count)
  PORTC = value;
  do {
    // toggle WE to write data
    LATB = WE_bar&0 | OE_bar | CP_en | CP_bar   | MR_en | MR_bar&0 ;
    // toggle CP to advance address
    LATB = WE_bar   | OE_bar | CP_en | CP_bar&0 | MR_en | MR_bar&0 ;
  } while (--count);
void GenerateLine(uint8_t vsync, uint8_t rgb, uint8_t count)
  do {
    write_SRAM_bytes( vsync | HSYNC   | rgb&0 , 16);  // front porch
    write_SRAM_bytes( vsync | HSYNC&0 | rgb&0 , 96);  // sync pulse
    write_SRAM_bytes( vsync | HSYNC   | rgb&0 , 48);  // back porch
    write_SRAM_bytes( vsync | HSYNC   | rgb   , 200); // video
    write_SRAM_bytes( vsync | HSYNC   | rgb   , 240); // video
  } while (--count);
void GenerateFrame()
  GenerateLine( VSYNC   , RGB(0, 0, 0),  33);  // back porch
  GenerateLine( VSYNC   , RGB(3, 3, 0),  240); // video
  GenerateLine( VSYNC   , RGB(3, 0, 3),  240); // video
  GenerateLine( VSYNC   , RGB(0, 0, 0),  10);  // front porch
  GenerateLine( VSYNC&0 , RGB(0, 0, 0),  2);   // sync pulse
  write_SRAM_bytes( VSYNC | HSYNC | 0, 2);     // end of vsync; resets counter
int main() {
  SetupPeripherals();
  LoadMode();
  GenerateFrame();
  RunMode();
  while(1){
    continue;
  return 0;
