Improvement of tower PVC pipe
A project log for UltraTower
Grow vegetables with ultraponics tower
J GleyzesJ Gleyzes 08/29/2022 at 16:282 Comments
The PVC pipe is an important part of this system. It is 100mm in diameter and 1 meter long, allowing 12 plants to be grown on a very small footprint.
Using the height allows us to optimise the number of feet per square meter.
This PVC pipe is essential for this project however the current PVC design can be improved.
Current design :
For each plant, this part must be printed.
It takes more than 1.5 hours of printing per piece, which makes 18 hours of printing for one tower. A lot of energy and plastic wasted.
Moreover this part gives a little too much horizontal angulation to the plants.
New design
PVC can be heated to make it take a particular shape. The idea comes from this youtube video
I thermoformed the large PVC tube with a small 40mm diameter PVC pipe which allows me to cut small 1cm long sections and glue them inside to make a small rim for the baskets.
When I have some time I'll make a video of how to do it.
I then painted the PVC white to reduce the heat inside the tube on sunny days.
Josh wrote 08/29/2022 at 20:35 point
The thermoforming looks beautiful! Have you considered cutting sections of pipe and bonding them at an angle to the main pipe? Cutting the shapes may be difficult, but with a template it would be reproducible quickly.
J Gleyzes wrote 08/30/2022 at 10:07 point
Thank you for your interest!
I thought of your solution, the small 40mm PVC pipe are easy to cut however the main 100mm pipe needs oval holes to give an angulation of 45° or more.
The thermoforming is for me easier to achieve.
