The FPGA device footprint and pinout for the Cyclone IV family is very similar. This design should fit with small or no changes to other Cyclone IV devices.
This is a PCB design I did to test Altium Designer's capabilities. I haven't tested it so I thought I could share the design.
Hi ! fist of all i want to thank you for the project , then i want to know how does the cyclone IV recognize the other devices? thank you
Here:
https://bitbucket.org/joseppinilla/adtboard
It is also on the repository section of my post. Let me know if you find a good use for it. Thanks for the interest.
Sorry I took so long. I have added the Design files to the repository
Hi man! the schematic have a bad image quality, can you share a better image ? thanks a lot!
