1DISCLAMER READ THIS FIRST
Some of these steps have not yet been implemented into the prototype glider such as the PCB and circuit rack print. If you attempt this build be prepared to make modifications as you go since this is not a completed design as of yet.
2Control Boards
Begin by printing the BackEndCircuitRack, and the Circuit_rack_encap_mount. We attempted to print these parts however the print failed part way through, for a more reliable method the stl file should be separated into two separate halves to print that can be glued together. Better yet would be to use the BlueROV pre-built circuit rack.
Once the parts are printed insert the Arduino Mega and Raspberry Pi into the BackEndCircuitRack. There are mounting holes in the print for them.
The circuit rack and all remaining 3D parts can be joined with wood or metal square stock in the provided rectangular holes. This design was from the OSUG project and was included to add some rigidity to the parts for when any of the actuators are running.
Have the PCB provided printed and solder on all of the parts as labelled on the PCB.
Connect the PCB to the Arduino Mega as labelled on the PCB.
Connect the Arduino Mega to the raspberry pi through a short USB cable and connect the pi to the portable power supply. Boot the pi and connect it to your local WiFi network, you should then be able to reprogram the Arduino wirelessly through VNC viewer.
3Roll Motor
Print the ServoRollMotorMount and attach the servo. This section will then attach to the brain housing. The servo can be plugged directly into the PCB. The ServoRollMotorMount print can be attached with square-stock.
This unit will then connect to the Pitch motor housing.
Print the Pitch_motor_backplate and attach the servo gear connection into the inner circle, for our prototype it was glued and zip tied in.
These two parts can then be joined. The gear you see being attached here will be replaced with a similar fitting (https://bc-robotics.com/shop/metal-rc-servo-arm-25t/) that also has a locking collar to keep both parts connected.
4Pitch Engine
Print 2 Battery_mount_bearings, the Pitch_motor_back_plate and the Pitch_motor_mount. Attach the linear bearing with zip ties to the Battery_mount_bearings and attach battery springs through the holes. Mount limit switches to the rails and insert them into the assembly. Connect the threaded rod to the stepper motor and mount the motor. Attach one of the Battery_mount_bearings to the brass nut threaded for the rod and insert the other end of the rod into a 5th linear bearing.
5Ballast Engine
Print the Ballast Engine Enclosure
6Bulk-Heads
Ensure all surfaces are cleaned thoroughly. proceed to lubricate and install O-rings.
7Vacuum
The glider requires a vacuum in order to operate. Begin by removing the vacuum plug from the rear bulkhead and insert a Blue ROV vacuum plug (https://bluerobotics.com/store/watertight-enclosures/enclosure-tools-supplies/vacuum-plug/). You can then use either their hand pump (or better yet a motorized vacuum pump) to pull a vacuum on the glider, preferable over 15 InHg. The next step needs to happen quickly, remove the vacuum plug and insert the original plug so as to maintain as much of a vacuum as possible.
If you want to measure the vacuum inside the glider, connect to the pi with VNC viewer and proceed to open the Arduino IDE and upload the BME280 test, this script can either be found in examples or in the library of scripts provided. Opening the serial terminal now should give you an output of the temperature, humidity and pressure inside the glider.
8Boot Sequence
To run the gliders dead reckoning test dives first turn both power plugs to on. If you want to reprogram the Arduino ensure that the 12V actuator power is disabled to avoid accidental damage. Wait for a minute or two for the system to boot and for the glider to run a brief diagnostic. While the glider is booting connect the long range radio to your computer and open the Arduino IDE and load the appropriate board (Feather 32u4) and connect to the serial port being used.
Open the serial monitor in the Arduino IDE and it should say the radio is 'Waiting for command". If the feather requires reprogramming simply upload the feather_command_control script provided.
The glider should be booted now, to run the test dive script send "dive" in the radio's serial terminal. The glider should being by shifting its pitch-weight forward, then its will open the first solenoid valve for the vacuum to pull water in, once it has reached a certain time (the final version will rely on a depth or altimeter measurement) it will pitch the battery back then proceed to open the second valve and pump the water out of the ballast.
If this does not happen open VNC viewer on your laptop and connect to the pi. Open the Arduino IDE on the pi when you've remotely connected and open the serial terminal on the Arduino, it will then tell you what went wrong during its diagnostics.
9CODE
The first code chunk declares the variables and establishes connections
#include <PWMServo.h>
#include "Wire.h"
#include <MPU6050_light.h>
#include "GravityTDS.h"
#include <SPI.h>
#include <RH_RF95.h>
#include "MS5837.h"
#include "ping1d.h"
#include "SoftwareSerial.h"
#include "RTClib.h"
#include <SD.h>
//#include <Servo.h>/////////////////////Servo///////////////////////////////
PWMServo myservo;
int pos = 0;/////////////////////Pump/////////////////////////////////
const int ENA = 35;
const int en1 = 37;
const int en2 = 39;//////////////////////Valve//////////////////////////////
const int ValveA = 28;
const int ValveB = 24;
/////////////////////////Altimeter/////////////////////////////////////////////////////////Altimeter////////////////////////////////
static const uint8_t arduinoRxPin = 10; //Serial1 rx
static const uint8_t arduinoTxPin = 9; //Serial1 txSoftwareSerial pingSerial = SoftwareSerial(arduinoRxPin, arduinoTxPin);
static Ping1D ping { pingSerial };//////////////////////////////////////MPU////////////////////////////////////////////
MPU6050 mpu(Wire);//////////////////SDA = 20, SCL = 21//////////////////////need to sort this out http://www.learningaboutelectronics.com/Articles/Multiple-I2C-devices-to-an-arduino-microcontroller.php
unsigned long timer = 0;///////////////////////////////////stepper pitch//////////////////////////////////For both Steppers red,yellow,white,green going away from capacitor/////////////////
const int EN_Stepper_Pitch = 22;
const int Step_Stepper_Pitch = 8;
const int Dir_Stepper_Pitch = 23;float Roll = 0;
int rollSteps = 250;int DiveAngle = 26;
int DiveRangeAdjust = 5;int depth = 0;
//////////////////////////////////int Ballast;
int MAXBALLAST = 800;
int TraverseBallast = 1400;
long DIVE;
int BallastDive = 4000;
int BallastRise = 2500;
int TIMEOUT = 100;////////////////////////Pressure/Temp///////////////////////////
MS5837 sensor;
////////////////////////////tds//////// This sensor is not currently installed but once a suitable fitting is found the code is ready and working
#define TdsSensorPin A1
GravityTDS gravityTds;
float temperature;
float tdsValue = 0;//////////////////////////////limit switches//////////////
int limPitchUp = 46;
int limPitchDown = 44;bool limitPitchUP = false;
bool limitPitchDOWN = false;/////////////////////////////Radio/////////////////////////
//#if defined (__AVR_ATmega3238P__) // G0 = 3, SCK = 52, MISO = 50, MOSI = 51, CS = 4, RST = 2
#define RFM95_INT 3 // #define RFM95_CS 4 //
#define RFM95_RST 2 // "A"
//#define LED 13
//#ENdif// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);/////////////////////////////////LOGGER////////////////////////
#define LOG_INTERVAL 1000 // millis between entries
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!#define SYNC_INTERVAL 10000 // millis between calls to flush() - to write data to the card
uint32_t syncTime = 0;#define ECHO_TO_SERIAL 0 //echo data to serial, 0 turns it off
#define WAIT_TO_START 0 //wait for serial input, if set to 1 then must send arduino a char to start logging//should make some logging leds for testing
RTC_DS1307 RTC;
const int chipSelect = 10;
File logfile; //the logging file
void setup() { This chunk turns on all of the connects and runs a brief diagnostic
Serial.begin(9600);
//Serial.begin(1000000);
//Serial1.begin(115200);
//Serial2.begin(115200);
//Serial3.begin(115200);//////////////////////////Steppers/////////////////
Wire.begin();
pinMode(Dir_Stepper_Pitch, OUTPUT);
pinMode(Step_Stepper_Pitch, OUTPUT);
pinMode(EN_Stepper_Pitch, OUTPUT);digitalWrite(EN_Stepper_Pitch, HIGH);
pinMode(limPitchUp, INPUT);
pinMode(limPitchDown, INPUT);////////////////////////////Servo//////////////////
myservo.attach(5);////////////////////////////////////////MPU/////////////////////////
byte status = mpu.begin();
Serial.println(F("MPU6050 status: "));
Serial.println(status);
while (status != 0) { } // stop everything if could not connect to MPU6050
Serial.println(F("Calculating offsets, do not move MPU6050"));
delay(1000);
mpu.calcOffsets(); // gyro and accelero
delay(100);
Serial.print("X : ");
Serial.print(mpu.getAngleX());
Serial.print("\tY : ");
Serial.print(mpu.getAngleY());
Serial.print("\tZ : ");
Serial.println(mpu.getAngleZ());Serial.println("Done!\n");
delay(1000);////////////////////////////radio//////////////////////////
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);// while (!Serial) {
// delay(1);delay(100);
Serial.println("Feather LoRa TX Test!");
// manual reset
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);while (!rf95.init()) {
Serial.println("LoRa radio init failed");
Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
while (1);
Serial.println("LoRa radio init OK!");// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
if (!rf95.setFrequency(RF95_FREQ)) {
Serial.println("setFrequency failed");
while (1);
Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);// Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 1238chips/symbol, CRC on
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
rf95.setTxPower(23, false);
//}int16_t packetnum = 0; // packet counter, we increment per xmission
//////////////////////////////////////tds/////////////////////////////////
gravityTds.setPin(TdsSensorPin);
gravityTds.setAref(5.0); //reference voltage on ADC, default 5.0V on Arduino UNO
gravityTds.setAdcRange(1024); //102 for 10bit ADC;4096 for 12bit ADC
gravityTds.begin(); //initialization////////////////////////////////////Barometer/Temp////////////////////////////
sensor.setModel(MS5837::MS5837_30BA);
sensor.setFluidDensity(1023); // kg/m^3 (freshwater, 1029 for seawater)sensor.init();
//////////////////////////////////////ping setup/////////////////////////////////// Uncomment this chunk to run without altimeter
pingSerial.begin(9600);
Serial.println("Blue Robotics ping1d-simple.ino");
while (!ping.initialize()) {
Serial.println("\nPing device failed to initialize!");
Serial.println("Are the Ping rx/tx wired correctly?");
Serial.print("Ping rx is the green wire, and should be connected to Arduino pin ");
Serial.print(arduinoTxPin);
Serial.println(" (Arduino tx)");
Serial.print("Ping tx is the white wire, and should be connected to Arduino pin ");
Serial.print(arduinoRxPin);
Serial.println(" (Arduino rx)");
//delay(2000);
///////////////////////////////////LOGGER SETUP////////////////////////////////////
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i / 10 + '0';
filename[7] = i % 10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
}if (! logfile) {
error("couldnt create file");
}Serial.print("Logging to: ");
Serial.println(filename);// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
}logfile.println("millis; stamp; datetime; voltage");
#if ECHO_TO_SERIAL
Serial.print("millis");
Serial.print("\t");
Serial.print("stamp");
Serial.print("\t");
Serial.print("\t");
Serial.print("datetime");
Serial.print("\t");
Serial.print("\t");
Serial.println("voltage");
#endif //ECHO_TO_SERIAL}
//////////////////////////////////////MAIN LOOP///////////////////////////////////////////// The code chunk that runs on a loop
void loop() {
digitalWrite(ValveA, LOW);
digitalWrite(ValveB,LOW);
pos = 90;
myservo.write(pos);if (rf95.available())
// Should be a message for us now
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);if (rf95.recv(buf, &len))
{Serial.print("Got: ");
Serial.println((char*)buf);
String command = buf;
//Serial.println(command);
checkpitchlimit();switch (tolower(command[0])) {
case 'd':///////////////////////////dive, return//////
Main Dive Loop (Enable uncommented code and reduce delays to run off of depth and altimeter readings instead of time
//digitalWrite(EN, LOW);
//digitalWrite(EN_Stepper_Ballast, LOW);
//digitalWrite(EN_Stepper_Pitch,LOW);depth = 0;
delay(2000);PitchDown();
delay(4000);
DECEND();while (depth > 1) {
Get_Depth_Temp();
depth = sensor.depth();
LOGDATA();
/*while (depth < 5) {
Altimeter();
Get_Depth_Temp();
LOGDATA();
delay(10000);
PitchUp();
RAISE();/*
for ( int x = 0; x < 1000; x++) {
Altimeter();
if (depth > 50) {
//ABORT();
PitchUp();
RAISE();
for(depth > 1.5){depth = sensor.depth();
break;
case 'b': ///////////////////////////turn right
depth = 0;
PitchDown();
Roll_Right();
DECEND();
Altimeter();
Get_Depth_Temp();
LOGDATA();
PitchUp();
RAISE();
while (depth > 1) {
LOGDATA();
Get_Depth_Temp();
Roll_Left();break;
case 'c': /////////////////// turn left
depth = 0;
PitchDown();
Roll_Left();
DECEND();while (depth < 5) {
Altimeter();
Get_Depth_Temp();
LOGDATA();
PitchUp();
RAISE();
while (depth > 1) {
LOGDATA();
Get_Depth_Temp();
Roll_Right();break;
default:
Serial.println("Invalid Input");
// Send a reply
uint8_t data[] = "Executing script";
rf95.send(data, sizeof(data));
rf95.waitPacketSent();
//Serial.println("Sent a reply");
// digitalWrite(LED, LOW);
else
Serial.println("Receive failed");
}//////////////////////////////////////////////////////////////// The rest of the Code functions
void ABORT() {//////////////////////////////////////////////////////////////////////////////////////abort func/////////////////////////////////////////////
Serial.println("ABORTING");
}void DECEND() {
Serial.println("DIVING");
digitalWrite(ValveA, HIGH);
delay(10000);
digitalWrite(ValveA,LOW);
delay(1000);return;
void RAISE() {
digitalWrite(ValveB,HIGH);
delay(500);
digitalWrite(ENA,HIGH);
digitalWrite(en1,HIGH);
digitalWrite(en2,LOW);
delay(10000);
digitalWrite(en1,LOW);
digitalWrite(ENA,LOW);
return;
}void PitchDown() {
Serial.println("Pitching Down");
digitalWrite(EN_Stepper_Pitch, LOW);
for (int x = 0; x < TraverseBallast; x++) {
checkpitchlimit();
digitalWrite(Dir_Stepper_Pitch, HIGH);
digitalWrite(Step_Stepper_Pitch, HIGH); // STEP HIGH
delay(1); // WAIT
digitalWrite(Step_Stepper_Pitch, LOW); // STEP LOW
delay(1); // WAIT
return;
}void PitchUp() {
Serial.println("Pitching Up");
checkpitchlimit();
digitalWrite(Dir_Stepper_Pitch, LOW);
delay(1); // WAIT
delay(1); // WAIT
return;}
void Roll_Right() {
for(pos = pos; pos>=45; pos-=1) // goes from 180 degrees to 0 degrees {
myservo.write(pos); // tell servo to go to position in variable 'pos'delay(150); // waits 15ms for the servo to reach the position } }
void Roll_Left() {
for(pos = pos; pos <= 135; pos += 1) // goes from position degrees to 180 degrees { // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos'
}void get_TDS() { ////////////////////////////////////////////////////////////////////////////////tds sensor func//////////////////////////////////////////////////
for (int i = 0; i < 25; i++) {
gravityTds.setTemperature(temperature); // set the temperature and execute temperature compensation
gravityTds.update(); //sample and calculate
tdsValue = gravityTds.getTdsValue(); // then get the value
Serial.print(tdsValue, 0);
Serial.println("ppm");
//delay(250);
void Get_Depth_Temp() {
int depth;
int Temp;sensor.read();
Temp = sensor.temperature();return Temp, depth;
void Altimeter() {
float DistanceFloor = 0;
for (int i = 0; i < 10; i++) {
ping.update();
DistanceFloor = ping.distance() / 1000;if (DistanceFloor < 2) {
ABORT();
return;}
void error(char *str)
Serial.print("error: ");
Serial.println(str);// red LED indicates error
//digitalWrite(redLEDpin, HIGH);
while (1);
}void LOGDATA() {
for (int x = 0; x < 20; x++) {
DateTime now;// delay for the amount of time we want between readings
delay((LOG_INTERVAL - 1) - (millis() % LOG_INTERVAL));//digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print("; ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print("\t");
#endif// fetch the time
now = RTC.now();
sensor.read();logfile.print("; ");
logfile.println(sensor.pressure());#if ECHO_TO_SERIAL
Serial.println(sensor.pressure());
#endif //ECHO_TO_SERIALlogfile.print("; ");
logfile.print(sensor.temperature(), 2);
#if ECHO_TO_SERIAL
Serial.println(sensor.temperature(), 2);
#endif //ECHO_TO_SERIAL// At the end of data logging the green LED is turned off
//digitalWrite(greenLEDpin, LOW);// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
// digitalWrite(redLEDpin, LOW);
void checkpitchlimit() {
int LimStatePitchFront = digitalRead(limPitchDown);
int LimStateRear = digitalRead(limPitchUp);while (LimStatePitchFront == LOW) {
digitalWrite(EN_Stepper_Pitch, LOW);for (int x = 0; x < 200; x++) {
//CheckLimitPitch();
delay(1); // WAIT
delay(1); // WAIT}
}while (LimStateRear == LOW) {
delay(1); // WAIT
delay(1); // WAIT}
