PTZplus WIFI Controller
The Digital Bird PTZ plus WIFI Controller for film makers allows you to control up to three independent camera systems at the same time.
Digital Bird PTZ plus WIFI controller for filmmakers. All the features you will find on the compact controller with the addition of live joystick camera control for up to three live camera systems while at the same time controlling unlimited automated camera systems set up using the A-B function or six key sequencer. A camera system can consist of any number of Digital Bird components, for example it may be a pan tilt head mounted on a slider or simply a camera mounted on a pan tilt head and a tripod. Whatever the configuration, the PTZ plus control can control up to three live systems. Up to six PTZ pre-set poses can be stored for each camera system and with version3 of the Digital bird software installed all recorded keys and positions are stored even when the system is powered down allowing you to setup your system long before the event power it all down to save on batteries. Power it up again when required with all your setups ready to go.
  • 1
    Step 1
View all instructions
