DIY Solar Lamp
Say goodbye to hassle with these DIY Solar lamps.
Save energy by installing a DIY solar lamp in your house. These lamps are easy to install and will provide hours of light whenever you need it. This is great for when the power goes out or when someone needs some light after sunset. These lamps also won't cost a thing as they are powered by solar energy!
With these lamps, you can forget about expensive electric bills, replacement bulbs, and maintenance work that needs to be done on traditional lighting sources. It's safe, reliable, and environmentally friendly!
Go green today with this amazing solar lamp.
After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JLCPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple steps which we will talk later.
Related Download Files
As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB assembled with all the components that we want to use for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
3
Place All the Components on PCB and Solder It Properly.
