To develop a water cooler to regulate the temperature of the feet or for some people with hot feet problem
Standard Tesselated Geometry - 2.48 MB - 08/28/2022 at 07:38 |
Standard Tesselated Geometry - 1.27 MB - 08/28/2022 at 07:38 |
Standard Tesselated Geometry - 189.73 kB - 08/28/2022 at 07:38 |
Standard Tesselated Geometry - 125.67 kB - 08/28/2022 at 07:38 |
Standard Tesselated Geometry - 91.78 kB - 08/28/2022 at 07:38 |
The following is the first version of the prototype.
whole assembly with my feet
Module Integration with the shoe
The cooler module with insole
Next time:
A few more tests were conducted to get the performance.
Objective:
Experiment setup:
Data of the cooling:
Data of the water tank:
Results:
Conclusion:
Although the temp. different was 4.9 deg, the water droplets were condensed on the insole and cooling pipe already. After the testing, I put my feet on the cooled insole and the cool feeling ran through my feet.
The requirement for the shoe mount is simple:
able to mount on a shoe tightly
I had a quick thought and designed a mount and test.
The following is the result.
It fit the shoe perfectly, however, it could not fit into another shoe. Therefore, the shoe mount must be modularized (design a mount for a special type of shoe) or add a degree of freedom to adopt more shoes.
The following is the design up to this moment. The moving parts would be self-assembled during 3D printing. This is the first time I tried to use this technique and the result was acceptable.
The requirement of the water tank:
The design of the water tank is below after testing
Experiment setup
The water tank shape could be further adjusted and also the way to couple with the cooler to get better performance. Since I could achieve the aforementioned requirement, I decided to move forward to see what happened.
The insole design was simple.
The cooling pipes run through as much as the area of the feet.
Attach a copper plate to the pipe
However, the cooling area may not be able to extend to the whole feet, and also the flat copper could be designed better to further increase the surface area. Therefore, the copper wires were used instead of the copper plate. As the copper wires were soft, the feet would have better contact with the insole.
The insole was welded and grided. After testing, the wires were able to deform a little bit to adopt the shape of my feet. I am happy with the design, of course, it can be better and that will be improved next time.
There are a few items I need to test before I start the design.
Testing items and results:
The experiment is shown below
Conclusion:
Considerations:
For cool feeling generation: It is noticed that to generate a cool feeling, a few degrees lower compared with ambient temperature would do the job.
Requirement:
Therefore, the design requirement was setup as below:
The process flow is quite straightforward.
The following is the conceptual design
Thank you very much, Cam. Yes, the printed parts (the inner surface of the mount) contacting my feet and that's unavoidable at the moment. However, I would say it was not scratchy and the feeling was acceptable. Alternatively, I could change the design or material, giving the user a better experience.
this is looking wonderful! you should upload the 3D printing files (or even 3D file sources) somewhere!
Thank you very much, Arya. I have uploaded the 3D printing files. Please let me know if you have any comments.
Sounds like the plan is to design an insole with electric pump and controller, which means you need a battery. Maybe you could use the body heat or movements to charge it, or move to a passive powered pump without electronics (also saver with water and foot electrocution). If you chose to go with electric, an interesting experiment would be to see if you can charge other devices (like leds in the shoe, or powerbank in a backpack).
Thank you for your idea and suggestion, Bart! That would be another good idea to be explored. Actually, I just finished the prototype and the information will be uploaded soon. I will be grateful if you can leave some comments afterward.
Very interesting project! Will the water pipes or 3D printed parts hit your calves when you walk with this?
