Why use an RP2040?
A project log for Canique Pico Gateway
An 868MHz to MQTT message gateway using a Raspberry Pico
caniquecanique 08/27/2022 at 18:240 Comments
When deciding which MCU to use as the core of this Gateway, there were a couple of things to consider...
Initial Requirements:
The minimum required Flash should be 200KB (100KB was expected solely for the TLS library). Currently the image has a size of 251KB.
The minimum required RAM should be 40K. Currently the TLS layer alone uses a static 50K of RAM.
Hardware encryption and/or a hardware RNG would be a plus (unfortunately RP2040 does not have either).
Still the price/performance of the Raspberry Pico was so good and the availability much better than the rivals (like STM32G0B0CE or STM32G0C1KC), that I opted for the Pico.
