This is the pico gateway in a 3D printed case.
4 self tapping screws are used to keep the enclosure parts together: M2.6 x 8mm
4 self tapping screws are used to mount the PCB to the enclosure: M2 x 4mm
A project log for Canique Pico Gateway
An 868MHz to MQTT message gateway using a Raspberry Pico
