Service messages
A project log for SPI4C
It's not SPI, I2C or I3C, it's another protocol with full duplex self-clocked links with 2×2 wires that is rich and easy to implement.
yann-guidon-ygdesYann Guidon / YGDES 08/25/2022 at 19:130 Comments
The low-level interface is very very lax and permissive and the frame-length filter helps a lot. Anybody could do anything but even incompatible circuits/peers should be able to discover they are not compatible... So let's agree on a "reserved message length" of 6 bits that requires very little complexity to support, and provide basic discovery and link status stuff.
First, the 2 leading bits must be 0 then 1. Any 6-bit message starting with a different header will be rejected. WHY ? So the peer can detect that the link works properly (all-1s and all-0s would indicate stuck or open signals) and if the message is validated, then it ensures that the bits are not swapped. A DFF+XOR can then be configured to "virtually" swap the data polarity, just as if we swapped the bits.
Then we have 4 bits or 16 combinations.
That's 8+2 combinations so there is room for 6 more. Nice. They are general and generic enough and if a peer implements very specific control messages (such as sleep/wake or such), a different length (longer) can be implemented without cluttering this simple protocol.
