Receiver PCB Board Assembled
A project log for Solar Powered WiFi Weather Station V4.0
An affordable Open Source Weather Station for Everyone
open-green-energyOpen Green Energy 09/27/2022 at 17:411 Comment
Today I assembled the PCB board, but the USB port was not soldered due to the unavailability of stock. As the USB port is not soldered, not able to upload the program now, Place the order for the USB-C port, it will be delivered by this weekend, I will update the results then.
Placed the components using Solder Paste:
Assembled PCB:
davidefa wrote 10/17/2022 at 08:33 point
Did you publish the software of the receiver ( I can't find it, I can find only a test program for the transmitter )?
