Pump or no Pump?
A project log for Off-Grid Garden Watering System
Solar powered watering system controlled with a Raspberry Pi to deliver an exact metered water volume to your garden plot, on schedule
scott-feldmanScott Feldman 08/30/2022 at 23:430 Comments
My version of this project uses a 12v diaphragm pump to pressurize the water.  It's an on-demand pump, which means it automatically turns on when there is a demand (ball valve opens), and turns off when there is no demand (ball valve closes).
If a pressurized water source is available, the pump is not needed.  Just hook the ball valve directly to the water source.
