Alternative communication devices
A project log for Beehive Monitoring and Tracking
Add and monitor sensors in a beehive to follow bees life.
gouttebrozeGouttebroze 10/15/2022 at 19:150 Comments
The communication options are as follows:
The data are saved on a SD card (for example) and the analysis is only done offline by removing the SD card.
The data are sent via the Sigfox network, the analysis is possible online.
The disadvantage is that the data size is very limited by the payload.
The data are sent via the Wifi network, the analysis is possible online.
The disadvantage is that you need to be covered by a wifi network, which is not always possible if the hive is far from your home.
The data are sent via the GSM network, the coverage is good. The analysis is possible online.
The disadvantage is that extra costs are applied for data management. The size of the data is also limited.
The data are sent via RF signals. The disadvantage is that you have to install a receiver in the same area and the analysis is not done online..
